This is the last thing preventing me from removing the tub and I cant get the steering shaft to come off.
Am I missing something.... I loosened the collars at the top and the one at the bottom where it attaches to the steering gear.
Any suggestions...
Larry 85CJ7, 350TBI ,T19 4spd
I had to use a big screw driver, a stanly bar, and a hammer to pry it loose at the bottom. It took a lot of time and muscle. Be carefull not to damage any splines when prying. I had to get me father to pull on the shaft from the top while pushed on it from the bottom to get it off. I recomend that you add a little bit of grease to it before putting it back on. You never know when you will need to take it off. Just be persistant.
Tim Springer
1980 CJ7
Make sure you take the bolts out! They fit in a groove and it won't come apart if the bolt is still in it. I have always had to whack them with a hammer to get them to come apart.
Loose nut behind the wheel
Born and raised in Jeep-Town
While you have it off why don't you upgrade to a new shaft from borgeson and get one of their vibration dampaners. The hammer is for getting the bolts out of the collar. Also I have taken the collars off so they wouldn't get in the way of prying, but its not needed. Thanks loosenut for telling him about the bolts; I forgot to say what the hammer was for.
Tim Springer
1980 CJ7
Re: Steering Shaft removal...thanks
Loose, Tim....
Thanks fellas. It was the bolts! I had not removed them from the clamps, I had just loosened them up. Came off quite easily....no hammer needed.
I think I will look into one of the aftermerket shafts. How much do they run roughly?
Thanks again,
I have a Borgeson shaft from Four Wheel Drive Hardware for $229.99 plus shipping. I however needed an adapter from Borgeson since I have a Chevy column. The traded me U-joint and had it to me the next day. Also I decided to get a vibration dampner from them to smooth the steering some. Check out their web site for more information on it: www.borgeson.com
Tim Springer
1980 CJ7
