Most steering problems on jeeps are easy to diagnose..just jack up the front end...both tires just off the ground and move one tire verticallay back and forth..up and down...shake it.....check out the ball joints...tie rod ends.....bearings....see whats moving....in theory..on a perfect rig...nothing should move when skaking your tites vertically. If its a tie rod end..you will see it give...as well as a ball joint. Get a friend to move it while you check it all out. If everything still seems ok...you could be getting some bad bump steer...and a clamp on steering stabilizer could be the ticket. Don't forget to check irregular tire wear...this is a HUGE indication of a bad bearing or mis-allignment.
chevy-Cj-7
chevy-Cj-7
