Is it possible to put a non-tilt steering column into a 86 CJ7 with Tilt?
I found a non-tilt for 50 bucks but I am not sure if I will have problems with the ignition switch. Will the factory harness plug into either one? I would like to put in a tilt but I don't use it so, the non-tilt is alot cheeper.
Thanks RCJ7
Shouldn't be any problem. The only difference really between the two is that one tilts and one doesn't - all the other stuff is the same.
