Guest
·I just finished the homebuilt steering brace! It looks great. I used two 5/8ths bolts to bolt a flat, 6x6" piece of steel to the inside of the framerail so that 2" stuck below the frame. I then welded a piece of 2x2" angle iron to the bottom of the plate so that it rests snugly against the bottom of the frame-rail. Then, I made a 2x6" flat piece of 1/4" that attaches to the output of the steering box with a u-joint. It is attached to the frame plate with a piece of 3/16ths walled 1.5"x1.5" square tubing. It will take the hand of God himself to move that steering box now. So I imagine that the next week link is the tie rods...right? Whaddya think? Weld angle iron to the outside, or put solid rod inside?
