I need help with the removal of my steering arm from a flat-top knuckle. I talked to Parts Mike and he said that you have to remove or atleast loosen the conical washers. No sure if I spelled that right. Any ideas on how to do this? Thanks!
/wwwthreads_images/icons/smile.gifEat, Sleep, JEEP/wwwthreads_images/icons/smile.gif
"James and the Giant Jeep"
1993 Wrangler 4.0/5spd, Herculined Interior, D44 w/Detroits and 4.56 soon to go in SOA
· Official Historian
Here's one I found:
http://www.coloradok5.com/axleswap.shtml
"Here's where it gets fun, remove steering arm (3 cone washers) from knuckle with large sledge hammer or impact fork."
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D/MSD/4.10s/lockrights
remove the nuts from the 3 studs, and hit it, spray it with penetrating oil, and hit it!
if that doesnt work HIT IT!
its 2 parts bolted together, the knuckle has studs sticking thru the upper piece, the upper piece has some tapered holes to hold those conical washers, the nuts on the 3 studs are all that seperate you and the those 2 pieces of wonderful GM steering enginnering from becoming really good pals.
HIT IT
OzarkJeep
"Bare foot girls, dancing in the moon light..."
