so far today i got through the first 2 steps of tracking down my distributor/timing/starting problem...based on my earlier observation that the rotor would spin when I tried turning the engine with the starter, my current assumption (which will no doubt come back to haunt me) is that the starter is operating properly, as the only way to get to the distributor from the starter is by turning the flywheel.
1. the distributor is solid when installed - the rotor won't move, even when it's in the "stalled position" between #4 and #1 towers (with the exception of a small bit of play for the advance springs)
1a. removal and inspection of the distributor shows the gear is solidly in place, the retaining/shear pin is intact, and the distributor shaft spins freely…
2. the cam gear does not spin when turning the engine over by the crankshaft - from what I can see looking down the distributor hole in the block, the teeth on it appear fine…
3. the rad, fan, shroud, alternator, belts, and front half of the vibration damper are removed…I picked up the damper through our national auto/household department store loan-a-tool program this evening, and will be pulling the damper and timing cover tomorrow morning…
on the up side, my mileage should increase after this due to the loss of weight from all the grime, sludge and grit I’ve cleaned off of the outside of my engine…
as to the terminology, rrich…by “spinning but won’t turn over”, what I was trying to describe (albeit not very well) was the sound; I heard a constant whir or whiz, like something spinning quickly, but I did not hear the RRRR-RRRR-RRRR (or whatever the sound is) you normally hear when the engine is starting properly…every time I was trying it with the key, I couldn’t see if the fan was turning…the one time my wife did it, I was looking at the distributor to see if it would spin, and it didn’t even occur to me to watch the fan (lesson learned), though I would think that if the rotor spun, the crank was turning: starter turns the flywheel which is attached to the crankshaft, which is attached to the camshaft via the timing chain…
and as for possible damage to the valves, can I see this if I remove the valve cover? I’ve been looking for a reason to take it off, clean up underneath it and redo the PO’s seal (they seem to have been students of The More The Merrier School of Silicone Application)...if it won't help me here though, i may leave it for another day...
