check your relay for wire placement. Simply put, the exciting coil that does the switching goes between your stock wire and ground. Connect those wires first. You can check as to whether or not they are correct by pushing in the clutch, then engaging the start circuit with the key, relay should click. The battery goes to the + side of the relay, or the one with the heavy duty contacts (should specify on the package, or the relay itself) Some relays have 2 or 3 outputs, easily identfied by the presence of more than one contact numbered identically. HTH.
