I need some help, since I got my 68 jeepster w/stock 225 about a year ago I've had intermittent problems with the starter, here's the scenario: The PO tried to re-wire this rig and bacically I've got spaghetti. He also added a push button starter, so you have to turn the key to the on position, then press the starter button (I don't believe that is a stock set-up). The ignition switch is stock, but you don't have to turn the key to the cranking position only the on position. (Nothing happens if you turn to the cranking position) The issue is about 50% of the time when you push the button no juice to the starter, you can see/hear that there is a power draw, since the headlights dim and the fan slows down, but she no crank! I then have to lift the hood and use my custom starting wrench and arch the solenoid to the starter and it fires right up. I tried replacing the push button starter but it didn't help, any suggestions or starting point (no pun intended) to try and troubleshoot this? It's really a PITA to have to raise the hood every other time I want to start old blue. There is no rhyme nor reason to when it works or when it doesn't.
Thanks in advance!
Thanks in advance!
