Does anyone have any suggestions on removing the starter motor from a 94 Pathfinder? I was able to get the bolts out but couldn't budge the motor loose.
Are you sure you got all the mounting bolts? There should only be a couple of bolts and one electrical connector to undo, then it should just fall right out. It is in a pretty tight spot, and with the short electrical connector makes it a bit of a bitch to put back on, but you should have no trouble removing the starter once everything is loosened off. You've got me stumped unless someone used Loc-Tite on it????
Sounds weird to me, it should come right out, check to see if the starter is pinched against something?
Sorry I'm puzzled?
Chris J.
/wwwthreads_images/icons/wink.gif Remember God forgives "ROCK'S DON'T" /wwwthreads_images/icons/wink.gif
