Diode Dynamics is excited to introduce our Stage Series LED Ditch Light Kit for the 2021 Ford Bronco!
The SS3 Ditch Light Kit for the 2021 Ford Bronco allows you to easily mount two SS3 Pods to the factory Accessory Ready mounting points near the a-pillar location, above the hood. No cutting or drilling is required! This kit will not interfere with the antenna, or raising and lowering the hood.
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in the SS3 collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency.
Learn more about our Total Internal Reflection (TIR) Optics | YouTube
Click HERE to check out the Stage Series LED Ditch Light Kit for 2021 Ford Bronco!
Simple connections. All SS3 LED pods feature a custom-molded DT type Deutsch-style connector on the back, and come with a 6-inch pigtail with bare leads. For installation, you can wire yourself, use an off-the-shelf Deutsch DT sized wire harness, or select an optional Diode Dynamics wire harness. Our Light Duty Dual Output Harness can be used to power up to two SS3 pods. You can also use our OEM Auxiliary Switch Dual-Output Wiring Harness to control your LED pods using the factory-installed aux switch bank.
Click HERE to shop SS3 Ditch Light Kit | Light Duty Dual Output Wiring Harness
Click HERE to shop SS3 Ditch Light Kit | OEM Auxiliary Switch Dual-Output Wiring Harness
Bolt-On Installation: The highly durable powdercoated aluminum construction utilizes the Accessory Ready mounting points for a bolt-on installation - there is no cutting or drilling required!
In the Box:
- Two (2) SS3 3" LED Pods
- Two (2) Deutsch-style wire pigtails
- Two (2) Mounting brackets and hardware
If you have any questions, please don't hesitate to post, PM, or email [email protected].
Thanks for looking,
John C.
Diode Dynamics
