Hey all,
my 94 path has sprung a little coolant leak. Its rather odd (I really dont thiink this is much of a problem ,but thought I would make sure). The resvior for the coolant on the pass side of the radiator fills up on occasion, way up past the "max" line on the tank. The truck isnt running hot, and it only leaks occasionally, but I just dont like leaks! Leaks right in front of the battery, and onto the headlight wiring clip and harness. Proceeds to run down the inner part of of the front fender, and make a little mess in my driveway now and again. Any help is appreiciated guys!
Happy Trails
Wade
The thermostat could be sticking. When you say leak you mean overflowing from the reservoir? When the engine is at normal
temperature the coolant in the reservoir should be at max, when it cools it lowers. Check the level when it's hot and if it's above
max, remove some coolant. See what happens then and go from there.
