1 - 1 of 1 Posts
Found some sites that might be useful for someone about speed correction after going to bigger tires the first is a place that sells tires and when you select the size it will give you the act dia. ie 35 dunlop mud rovers are 34.1 in so if you can find the stock tire rolling sizes for your new and old tires you can go to the next site and it will calculate the speed difference between what the sppedo says and what you are actually doing
http://www.therangerstation.com/Speedometer_Change_From_Tires.html
http://www.etires.com/
1 - 1 of 1 Posts
