/wwwthreads_images/icons/tongue.gif Brit,....not only were our rear shackles shot, but the bolts were hopelessly rusted as well, and the rear frame horns were thin in places. What we did was make the bumber brackets BECOME THE SPRING HANGARS. Using 2 X 2 heavy wall square tube, we drilled and inserted a bushing to take the poly spring shackle bushing, then the 2 X 2 had big plates welded along the top edge above the spring shackle level which rose up on each side of the frame and bolted through in several places. The 2 X 2 then bolts to the bumper, which also bolts to all of the holes in the rear frame crossmember. So you see, Brit, we not only put the bumper weight right to the springs, but tied everything together on the rear of our frame as well./wwwthreads_images/icons/crazy.gif/wwwthreads_images/icons/wink.gif/wwwthreads_images/icons/smile.gif
I never believe any statistics unless I've made 'em up myself.
