Guest
·I just changed spark plugs in the 4.0l in my '98 TJ. I had noticed a slight power drop-off a while back, just like our '88 LeBaron Coupe (2.5l) does when it needs new plugs. After 29k miles, new plugs seemed reasonable. I bought a set of Champion truck plugs in hopes that they will last longer. The factory service manual specifies 0.035 gap, but the new plugs were gapped to 0.040. I tried bending the side electrode to get 0.035, but it looked like I would risk breaking it before I would get a nice even gap. I recalled that on Mopar 318 V8s, the specified gap was 0.035, but they ran much better with 0.040. I went ahead and installed the plugs with 0.040 gap. Does anyone have experience with running different gaps on the 4.0l? BTW, the old plugs were running a little more than 0.040 gap due to wear.
Another issue, has anyone else found that the original plugs were difficult to break loose? I had to use a 1/2" breaker bar and a fair amount of force to get the plugs loose. I broke the insulator on two of them. I've never had plugs stuck this tight in either cast iron heads or aluminum heads, and have never broken insulators, and I've been changing plugs for 20 years. Granted, these plugs take a 5/8" spark plug socket, so I couldn't use my trusted 13/16" spark plug socket. I used anti-seize on the threads when installing, so next time should be easier. I also spritzed a little silicone spray into the spark plug boots in hopes that they won't be stuck as tightly, either.
Bill
Bill
