Alrighty folks, I need some measurements trivia.
Need to know the length off..
4.2L (from crank nut)
AX15
NP231 (output yolk)
Figuring out this 350 swap..
I;ve got..
26" for the SBC, 6" bellhousing, 12" SM465, 8.5" Homebrew adapter, 11.75" D300.
That's 64.25" From cranknut to output yolk.
Hows that sound for my YJ?
Sweet.
31"
the AX15 is 24 right?
Tcase from mounting face to end of the yolk... when in a nutral state.
So I'm 26 to my 31
5"
SM465 and adapter is 20.5" to the 24.
Thats another 3.5"
I read somewhere that the NP231 is 19? is that true..
cause then it's 19 to the 300s 11.75
7.25"
15.75" shorter then my current setup?
I think I could probably even run the cheap slightly offset J20 axes a guys trying to sell around here.
That sounds long for your orig. set up.....but I don't know a thing about those trans/t-cases.
Just for reference this is a stock CJ7 set up........
4.2 = 31''
bell = 6.5''
T-18 = 13''
D-20 = 10.5''
61.0''
looks like you're in the neighborhood.
Shazbot.
Forgot the bellhousing.
6"
I keep trying to measure under my Jeep.. but it's so hard with it all still bolted under there.
Was hoping some people pulled tcases and trans and measured them out.
Bump. Im back to math.
Now Im comparing a Th350 in there aswell..
26-6-25.3 (w. adapter) - 11.75
orignal
31-24-19
I've got an electric taurus fan.. thats got really good clearance.
I'm kind of stuck here.
I've bought the SM465 and D300.. it'd be good if I could use the D300, and mate it to a TH350.
This making any sense? Im rambling I know.
