Have a good friend thats absolutely losing his mind as to what front solid axle to use for his 86 hardbody pu. Anyone got any suggestions?
Dana 44 all the way ! Why go leaves in front when you can keep coils with the 44 not to mention that if you use the Chevy outers you can keep the same bolt pattern.
Check-out "Wild Horses" That's where I got my axles. They have a custom Ford Inner & Chevy Outer set-up all ready to go for about $350.00 US if I remember right?
Chris James
"Go Solid or Go Home"
Hi, Can't use an older toy axle because the driveshaft is on the wrong side to match up to the nissan transfer case,
TONY(HARDBODY)
