Guest
·When doing a SOA suspension how do you keep the caster angle the same as spring under. Also when swapping in different axles (Dana 60 front 14 bolt rear) than stock how do you decide the where to mount the spring perches; besides the same width as the stock axle. The rear axle seems fairly easy, but any advice or things to look out for on the front axle would be appreciated. Thanks
Tim Springer
1980 CJ7
Tim Springer
1980 CJ7
