I knew there were things to fix on her when I bought it. I didnt expect any major problems though. I did the first oil change on her and now she smokes on startup, only lasts a second, but im kind of concerned. Being its only when you start it, would the problem be in the valves, or is it still a possability its the rings? I did notice when I changed it the oil was really thick, possably to easy the smoke problem?
Also, she seems to run strong and has plenty of power, but when you go to start it the motor has to crank over a couple times before it starts, unless you press the gas in a little bit, what are possable problems in that area? I already did plugs, cap and rotor. It has about 130,000 on the clock.
I appreciate any ideas, this stuff gets kind of annoying
JAG
Las Vegas NV
90 X-Cab Toyota V6 5Speed, 4 inch procomp, 3 inch DC, 35x 12.50 BFG Baja's./wwwthreads_images/icons/cool.gif
87 K5 Blazer Silverado Bone stock. The womans ride.
JAG
Las Vegas NV
