Guest
·I know this has been hashed out before. I'm using a Buick 225 in my 67 Jeepster. I want to keep a manual transmission but go to one with a granny gear. I am looking into the SM420. or Ford 2wd T18. What I really don't want to do is pay 500 bucks each for the adaptors. I would rather use a combination of parts that might be able to be replaced out of a Salvage yard. I believe the Ford T18 can be bolted to the stock V6 Bell housing with some work to the Bell housing. What about the input shaft and clutch ? Since the Jeep Dana 20 won't bolt up to the ford or the Sm420 then what about changing to a different xfer case ? IE ford or Toyota or GM. Adaptor plates that can be made locally are ok and some machine work to modify parts is ok. I just don't justify the one of a kind adaptors expense. I'm starting with a buick 225, 3 speed stick (T14A ?) Stock Dana 20 and stock rear end. DanA 30 with disc in front. I know that the driveshafts are going to have to be custom but that's a given as heavier duty than stock is needed and there is usually a driveline shop close around. If I'm wrong on any of my thoughts let me know because I've just started researching this out. Thanks in advance for any help.
Lenny in Colorado Springs
67 Jeepster 225 V6 & 3 speed
96 Dodge Ram 2500 V10 AT CC LB 4x4
