Skyjacker 2\" lift on CJ7 - only 1\" difference
I installed a 2 inch lift from Skyjacker on my stock CJ7. I measured the front and back before installing the lift as per their instructions. After I installed the lift and jumper on the Jeep and drove it around the block, I measured again. I only got a 1 inch difference. I don't have a winch, or a hardtop or had doors. I have a stock 258. Any ideas why I would only get a 1 inch increase in height?
I went to Skyjacker's site but could not find a number for tech support, any have the number?
What do you guys think I should do?
Thanks for any help.
[email protected]
Re: Skyjacker 2\" lift on CJ7 - only 1\" difference
Maybe they sold you a set of "pre-sagged" springs to keep you from being disappointed in the future /wwwthreads_images/icons/frown.gif
_____________________
John
95.5 YJ with "stuff"
http://SonsofThunder4x4.com
Did you originally have the factory HD spring packs? Something like 6 leafs /front, 7 leafs/rear (or vice-versa). If you did, your Jeep already sat 1" higher than the stock 4/5 leaf setup. This may be why. We put a set of Skyjacker 2" springs in my bosses YJ and got about 2.5" of lift with a hard top and hard doors. Just something to check.
Mike H.
1983 CJ-7 Laredo
1999 Dakota 4x4
Mike, you are probably right. I think I do have the 6/7 spring pack. I'm gonna double check tonite. BTW, they do ride much softer than my stock springs.
[email protected]
