1 - 8 of 8 Posts
The body will be off this weekend and then the real work starts. Has anybody here replaced a flatfender frame with a more current one say from like a 70 cj?
I want a little longer frame cause mine is so short. Is there something else I can use? Any suggestions or web sites to look at?
I am building this thing from the ground up and want to do it right the first time.
Cut to shape, hammer to fit, paint to match /wwwthreads_images/icons/wink.gif
Project '51 willy's total rebuild /wwwthreads_images/icons/cool.gif
Just sending back to the top. Anyone got an opinion?
I will be doing this soon, after I finish the body mounts and diamond plate bed on the Scrambler. JEEPNCHICK's '47 frame is also shot, but I managed to pick up a mint M-38 frame, complete with axles and steering gear (and tie down points). I'll probably go with the CJ-2A axles, as they're lower geared, someone correct me if I'm wrong or if I should keep them.
I have a friend that is building a flatfender with a DJ-5 frame, apparently it's 4" longer than the CJ frame and he wants to do a shackle reversal with the extra length.
I don't know of anyone that has replaced a frame with a more current one, but with some modifications and a little ingenuity anything is possible. Sorry I couldn't be of more help, just didn't want you to think anyone wasn't paying attention.
JEEPN
'81 CJ-8 Scrambled!
Stomper, Jason Bunch of Tri-County Gear is running an early model CJ5 frame on his flatfender. He said it's stronger than the original.
Gary
Thanks for the reply. I WAS begining to wonder.
My step dad had a '50 flatfender that he claimed was on a '70's frame. But getting him to do anything is like pulling teeth. I might see if I can get a DJ frame, I want to go SOA with a shackle reversal, but I think I want an automatic too. I need the extra length for that.
I will try to pry some info out of my step dad to see how hard this would be and let you know.
Jim, check with Rich at R&P 4wd 503-557-8911, I think he has a frame or two lying around that would work.
dan
Good things come to those who do research!!
I lenghtened the frame of my CJ-2 6 1/2". It now holds a 302 Ford, T-18, Dana 300, Dana 44 front axle and a Dana 60 rear axle resting on YJ springs that are spring over. I boxed the frame and will be adding some fishplating sometime in the future in the area of the spring mounts. I also lenghtened the body 6 1/2" for leg room. Might be easer than cutting up a complete frame to make it fit.
Rob
1 - 8 of 8 Posts
