It's interesting that different states, even different counties and cities have different rules regarding smog devices, and the method of testing.
Some only do a tailpipe "sniff," if it passes the hood never gets opened. So you could have anything under there, as long as it's clean enough, who cares.
California seems to have the toughest though, but other states are following suit. Depending on the area, most of the testing is done on a dyno. Measurements are taken of the exhaust at speeds of 15 and 25 MPH under a light "cruise type" load. That means depending upon weight, the dyno loads the wheels to simulate actual driving conditions, loading it between 25 and 50 HP, trying to approximate actual driving conditions.
Then the next part of the inspection begins, no matter whether it passed the emissions portion or not.
It's a visual and functional tests of the devices themselves. Theorey being that it may be running good now, but later on it may develop a misfire or something, the devices still clean up the mess till it gets repaired.
As a general rule of thumb, everything must remain as the original manufacturer of the vehicle built it and obtained "Type" approvals in that configuration. It also goes by the engine and body years, whichever is NEWER dictates the standards and devices required.
So putting a 4.3 in a '69 is inviting problems. Fortunatly if the registration calls the body is too old to be smogged they'll never know. But ---- there are roadside checks sometimes - they'll catch it. Just be aware of the possible hassles. Putting in a Chevy 4.3 with TBI would necessitate installing the CAT, EVAP, - everything, then getting it "approved" at a referee station - near impossible.
A few "Tips" on getting it passed:
We all know how how familiar mechanics and parts guys are with Jeepsters. Sometimes it's even a fight to get them to understand Jeepster, not Jeep. Take advantage of it.
Start by making everything look stock original. Ditch the chrome, paint the aluminum. Don't let it look like the engine's been swapped, especially for a newer one. Even a bone stock 225 will get a fight from the smog guy if he gets wind that it's a Buick engine - he'll think it's not original. Books and data bases do not cover older vehicles very well. Don't do anything that will make him wonder.
He's under obligation to pass it only if it qualifies, if he "cheats" or even "misses" something he could be in big trouble, like heavy fines, loss of license, even jail time. The laws are against him. In some cases it's almost as bad as bank robbery, so try not to put the poor guy in jeapordy. If he see's something questionable, he'll fail you out of fear.
Smog offenses by a smog mechanic are Napoleonic Rule, guilty until proven innocent. He doesn't even get a trial in real court, he's judged and sentanced by a kangaroo court of politicians, many of whom don't have the sligfhtest idea about how engines work.
Red flag - Do not leave any vacuum hoses plugged or disconnected. A hose with a bolt in the end is a huge red flag!
Remove all non-used brackets that he may wonder about (or a state spy.) He'll assume somethings been modified and start looking closely - even if nothing's been done he'll usually fail you.
Even little things like using a heater hose for an air pump hose is a no-no. It works, probably even better than the stock hose, but it's "Modified." Make it at least look stock.
Before taking it in, make sure it's running properly, if it's missing it won't pass, save your time.
Make sure your exhaust system isn't leaking.
Make sure you have a fresh tank of gas in it. Drain or use it till it's almost completely empty, then fill it all the way up. You want to dilute any old gas in the tank with fresh gas. Many of the additives they put in gas only last a few days, so even week old gas can make a difference. Premium vs Regular - probably makes no difference, but fresh does. But, don't use ARCO or cheap brands, they use too much alcohol, HC may flare up. Stick with the major's for this.
Bring it to him hot, put at least 50 miles of highway driving on it, not stop and go, then pull right into his place. Don't let it idle while you fill out the paperwork or wait, shut it off completely.
It doesn't hurt if you are there when he's busy, sometimes he'll have a tendancy to rush, often to your advantage.
You wouldn't ask a friend, or even a stranger to run across the street and rob a store for you, so don't try to bribe him. You both could end up sharing the same cell. Instead help him pass you, make it easy to see it's original, the paperwork is in order, and you don't want to delay him from his "busy time."
Most generally the rules are determined by where the vehicle is registered, usually your home. Be careful registering it in another state or county where its not as restrictive. Most states have laws about how long a vehicle is in their state before it must be registered there. I've been stopped several times and questioned, one of my trucks has Arizona plates, my drivers license is California's. I carry proof I own property at the listed address in AZ, but still they argue. Who's to say that even though he's seen my truck around for a long time, I haven't been back to AZ with it in the last 30 days? Story time. Nothing illegal about owning property in any state you wish and living there part time. - at least yet. But be prepared.
We all benefit from clean air, so keep it clean, but there'sd a point where reason becomes absolute stupidity. Unfortunatly laws written by politicians reflect their intelligence. (Who in their right mind would want to be one?)
98% is Understanding it
"Don't Fix Unless Broke"
