Guest
·Thanks for all the responses to my post a few days ago, asking whether I should buy a Samurai or a Sidekick for light offroading in the Pacific Northwest. Based on the recommendation of going for the Samurai, I've got one in mind. Does this sound like a reasonable deal?
- 1988 (I think it's the 1988.5: it has square dash vents)
- 113,000 miles (183,000 km)
- Asking $2,000 US
PRO
- Good stock size tires
- Newer exhaust
- Runs well and not blowing any blue smoke
- 4WD engages well
- Clutch engages well (with slight whining noise, perhaps release bearing, when pedal depressed)
- Some rust, but not bad (floor is solid)
- Brakes feel strong
- Suspension firm
- Used as a street commuter
CON
- Minor oil leak from passenger side of engine; couldn't see where it was coming from
- Some oil on underside of floor panel above transfer case
- Parking brake doesn't hold
- Rad has some corrosion
- Soft top pretty worn out(but no tears in it)
He hasn't used it for two years, and it's not licensed so I couldn't drive it.
What do you think? Anything else I should check on it? I didn't check compression, and I forgot to look into the rad to see if there appeared to be any head leaks (is that often a problem with Samurais?).
Thanks again; you've been a great help already!
- Asking $2,000 US
PRO
- Newer exhaust
- 4WD engages well
- Suspension firm
CON
