I hope its ok to post ads on this board since the classified system sucks.
Quadratrac transfer case for sale, with low range, from a '76 CJ-7 $100
Jeep TH400 for parts only, partly broken bellhousing, $40
also, CJ brake clutch pedal bracket assembly, $40
258 flywheel $??
located in Raleigh, North Carolina.
Mark
Re: semi-OT: Quadratrac stuff for sale
Im all about the clutch master cylinder if its in good shape?
also please give WILL dibs on that Qtrack if he still needs one!
Ill email him and tell hiom to check this thread!
OzarkJeep
too small to be seen, and too big to control, and treated like a walking bomb...
Official Historian
Thanks for looking out for me Matt. The strangest things have happened since our outing. Later that night, I got the vacuum pump out to try to figure out why the transfer case wouldn't lock and it worked the first time.
As for the feeling like I had a hub still locked in, I got to work one day last week and one front hub was much warmer than the other and the lockout was loose. (Darn bolts - there are now studs on that side.) I thought I had lost the bearings but it turned out to be worn brakes. It's been back to normal for the last few days since I put new pads on. I can't explain it.
im glad you saw this, I dont have your emial address anymore so I was gonna have to leave you a BBS message.
the caliper is probably on its way out!
glad you got it licked.
OzarkJeep
