scout axles
1418 Views 10 Replies 3 Participants Last post by  **DONOTDELETE**
I know of a 65' scout in a junkyard.
Can someone help me figure out if they would fit my cj2a or a friends CJ-8??
Any link would be great.
What would be the best year? Thanks
william
http://www.medicalpark.net/jeep/
1 - 11 of 11 Posts
If you want disc brakes and the 1pc axles, I belive you want the Dana 44s from early 70s to 80 Scout II. Mine came out of a 1978. Good Luck!
http://www.tmcom.com/~tsm1/scout/faq/axles.html should help some. The '65 Scout axles weren't very desirable, I'd try looking for a later model one, like '75 -'80. I also have the axles from a '78, you should be able to find them very cheap. In '65 the front and rear were D27's, optional tapered D44 in the rear. Both had Powerloks though.
JEEPN
'81 CJ-8 Scrambled!
hey jeepn i also have found a scout for sale, it is a 78 also, my friend is selling it and this weekend i am going to find out what he wants for it and found out the exact gear ratio, he believes that it is posi so that would mean it has a tracloc? are they any good or is a locker that much more superoir? also if it does have a tracloc and i decide to go to a locker will those gears work with the locker or will i need new gears?
84CJ7:
78 is a good year for scout axles. Should be D44 front and rear. Could be a limited slip differential such as Power-Loc (Posi traction, Power-Loc, Trac Loc all essentially the same). Limited slips certainly give more traction than open diffs, if the clutch plates are not worn out. But, no limited slip is ever going to be as good as a locker.
Only one locker, that I'm aware of, will work in a limited slip carrier..the new Powertrax gearless locker. But don't let the limited slip keep you from buying the axles. You can always buy an open carrier ($50-60) and, depending on the gears in the axles, you may need a new carrier anyway if you want to drop down to 4:10s or lower gears.
Lock-Rights and EZ Lockers are inexpensive (comparatively speaking) and fit inside an open carrier and will work regardless of the gear ratio. Detroits replace the carrier, but there are different size Detroits depending on what gears you have or want to run. If you want to run Lock-Rights you can keep the gears it has and just buy a new carrier. Or you can buy the new Powertrax gearless locker and put it in the limited slip carrier.
Shain
See less See more
shain
I am planning on buying the scout regardless the price is right 100 bucks and i can drive it home! but the problem is it seem that i might just be better off keeping my axles? my amc 20 has a locker and a one piece axles already but no gears plus it is already in my jeep soa and every thing is perfect in the rear but the front... i am not sure if the dana 30 is up to my challanges with a locker and gears going into a front axle i do not know if that axles is uop to par!
whats is your opinion on the rear?
later
andy
If you swap in the front why not the rear as well. Also some of the 74 scouts came with Dana 44 and some with Dana 30. Also some came with drum brakes and some with disk. Axles are pretty cheap too. I know of a complete v8 scout for $300 and it ran when it was parked. I'd buy it but the front diff is on the wrong side.
87 wrangler
dirt dog
the reason why i would think of not swapping in the rear is because i already have (one piece axles yes i know the scout would not need an axle upgrade but that strenths the amc20 and a locker) but if i get the scout rear i will need a locker, possibly gears they are 3.53 i think i will b=find out a definate this weekend, 3.53 with running 35 and 36 is probbaly not the best so know i would hav to start all over and buy everything gears 2lockers vs a set of gears and one locker the diffrence in me having them both in my jeep is the price of a locker derriots 400 and some time to put the rear end in the jeep
later
andy
Hi, Mark, everyone. My name is william.
I had the question about the scout axles. I wanted to ask another. Do the axles just line up with spring purches and driveshafts? I have a rear dana 44 located, off of a CJ3A with the stock 10 spline 44 shafts. I would rather have front/rear dana 44's with the 27 spline shafts off a scout but im not entirely sure the pumpkens will line up with the t-18 transfer case. What do ya think?
Thanks in advance,
william.
Howdy!
If you do a search on Scout axles, you'll find quite a bit. Scout's also had 30 spline axles, not 27, but a far cry above the 10 spline anyway. No, they will not bolt right in, you will need to move the rear spring perches and either have the front cut down (one side) or move the springs outside the frame. The pumpkin is on the correct side for the Model 18 for the front, but the rear pumpkin is centered. If you cut one side of the rear down you can offset the pumpkin. I do know of a guy that swapped a D44 (not a Scout one, but centered pumpkin) into his '67 CJ-5 with Model 18 transfer, and he has no problem, he's even running a 2.5" superlift and 33's. Keep in mind these axles will be a lot wider than the stock CJ-3A ones if left uncut. I don't know about the driveshafts, I cut down some from a Wagoneer to fit as they're a lot stronger.
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7" Lift/33" Swampers/Scout II D44's F&R 4.10's & Lockrights
Andy:
Sorry I didn't respond to your post sooner...weekend was here and I was away from the computer. I understand what your saying about the AMC 20 and the costs of swapping in D44s, lockers and gears. The $100 running Scout is a no brainer...you gotta buy it. But I'm usually a cheap ass. I'm spending $ like crazy right now with my D44 swap, gears, detroits, axle bearings, seals, brake shoes, etc...its killing me. If you don't want to spend a wad of $, after having acquired another 4x4 for $100, I'd just leave it as an extra play toy for right now and maybe put a Lock-Right in the front of your Dana 30 for $250...h*ll you might even weld the front spider gears. Then just give it h*ll and see what the Dana30 will hold up to...you've now got d44s as replacements if the Dana30 shells. You might be suprised. There are alot of guys out there running D30s with 35s and lockers and 350s or 360s. I just saw one of Peanut's (Kelly Van Zandt's) with a 360, 35 boggers, lockers and the ol' Dana30 up front. My Dana 30 with a Lock-Right has held up...with the exception of blowing axleshaft u-joints (BTW, use the Napa super strength u-joints in your D30 if you put a locker in it). The AMC20 with 1 piece axles is probably as strong as the D44...you'll break the D30 long before the AMC20.
If you gotta swap gears, do the Dana44s. The gear swap and stuffing D44s under your jeep has a lot of sh*t that goes with it. It's not just a bolt on, low cost, 1 day project. I don't think I'd do a gear swap with your stock axles when you've got D44s right under your nose. Just rough estimating it, a gear swap and front locker for your stock axles will run $420 gears and install kits, $250 Lock-Right, installation of gears $300= $970, plus probably $100 for new carriers if you go down to 3.73s or lower.
Gear swap for the D44s is something like $420 gears and install kits, $250 each for Lock-Rights, $50 ea. for new carriers, installation of gears $300 = $1,320. Not much in price difference to go to the D44s. But your still gotta set 'em up underneath your jeep, correct the front caster, possibly modify driveshafts, maybe new rear axle bearings and seals on the rear, weld on spring perches for your SOA, etc... You can always sell your AMC 20 or part it out(1 piece axle, locker, housing) and make up a little money. This is the most expensive option but will get you what you want in the end.
Another option. you could put the Scout axles under your jeep now with their current gears. With your 360 and the 3.54 in the Scout axles you could turn 35s okay with out a gear swap right away... maybe an improvement over your current gearing. Buy an open carrier for the rear and put a Lock -Right in it. Or weld up the Scout rear (if you can with a lmtd slip) and be basically where you are now...doesn't matter that its welded up you'll eventually swap gears and buy a new carrier with your lower gears.
If you need open carriers for 3.54s I've got 2 I'll sell for $50. :)
Shain
See less See more
1 - 11 of 11 Posts
