if you lift the late modle trucks (s-10's ) the front driveline is not a workable unit anymore - i can make a new type heavy duty - e mail for more info- [email protected] -jesse
I have no idea what you are talking about. I have an 88 w/ the trail master lift on it and my drive line works just fine. My friend has an 85 blazer w/ the same lift and his work fine too.
I have a S10 on top a pre 79 Ford Bronco chassis. The front end is a straight axle. I had it looked at by a 4x4 specialist and he said I would need a transfer case that is clockable. I can unbolt the case to rotate it. The output shaft moves downwards to reduce the pinion angle. My lift is way up there, maybe 15 inches or more. I have alot of work to do.
