If that's the actual reading in F, it's way low. Your thermostat is probably stuck open. It should run around 185-195 degrees F. It may be lower at idle but when running at a higher rpm, it should be in the higher range.
Nick Hagen
1995 Wrangler
Nick Hagen
1995 Wrangler
