Check to see if your Thermostatic Air Cleaner is working correctly and the flapper is open to the heat stove pipe from around the exhaust manifold after a cold start up. That helps the engine warm up faster by using hot air from around the exhaust manifold to vaporize the gas when the engine is still cold. Good Luck!! /wwwthreads_images/icons/smile.gif
