Has anyone reversed their carb on their jeep? I know some of the benifits I think I read a bit about it somewhere but I don't know much on this so any advice or info would be greatly apeciated. I'm off work for a bit so I have time to tinker, (not much tough)
Chad
84 & 76 CJ-7's Give me a striaght six cummins diesel anyday. [email protected]
If you have a problem with fuel flow when climbing hills, when you flip it around you'll have problems going down hills. Thats about the only problems I can think of, except for linkage and fuel lines.
pbm
74 cj5,304,t18,2.46 ts d20,30f,44r,soa,MORE buggy front,35's,Rci's,5pt,full cage,air,etc.
Support Search and Rescue.......Get Lost! /wwwthreads_images/icons/shocked.gif
downhill is ok I just like being able to get up them I wonder how the throttle linkages would work?
Chad
I would think a cable throttle would be the answer to the linkage.Just get a longer cable. Go around the engine ot the front. Make a bracket to hold, and add a spring on the other side to return the carb lever.
Dan Stewart 1963 CJ5 "Caloosa Jeepers" member
ya that sounds like the answer, I might give it a try and let you know how it works out and plus sides and problems with it. It wont be for a bit I don't think. Moneys a bit of a problem right now I only have a bit.
Chad
ya I read up on him in Jp magizine. That's a crazy rig. I didn't know he ran reverse carb tough.
Chad
