It is often amazing how much you can learn when you are trying to learn something else. While thinking that I would just check the timing and verify that I had the distributor using ported vacuum I noticed that the idle speed increased when I took the lid off the air cleaner. Then I noticed that occasionally the idle speed would just drop about 300 RPM. 1984 258 I6 original distributor and BBD carburetor.
Well, yes I had the distributor vacuum advance working as desired with the ported vacuum source.
So why would the idle speed increase just by removing the lid of the air cleaner? A dirty air cleaner could do that. More likely is the stream of exhaust gas coming out of one of the Pulse Air tubes. So I have a bad check valve. At this point I do not have vacuum to the "three solenoids", so does this mean I also have a bad vacuum operated control valve on that side too? It is one of those things that you look at and it just seems to display that attitude of "this won't be as easy as it looks". Does anyone have suggestions for making it easier? Should I change the other check valve while I am at it?
So why does the idle speed just drop occasionally? I have a theory that seems promising, but am I overlooking something more obvious? Would the computer be doing this? The best looking clue came from the timing light with the vacuum advance disconnected and plugged, and the two vacuum switches electrical plug disconnected. At the slowest idle speed the timing looks to be 2 ATDC. (Yes I know that 6BTDC would be better.) Blip the throttle open and the timing advances, so mechanical advance is working. The idle speed stays a bit high, timing is around 8 BTDC. After a little bit the idle speed drops to slow and the timing is now back to 2ATDC. So my theory is that the mechanical advance is sticking and takes some time to get un-stuck when RPM drops to idle.
I haven't been this deep into a distributor for a long time, so can I get to the mechanical advance without removing the distributor from the engine? Any tips on fixing this?
Detail: the decal says 16BTDC @ 1600 RPM
