I just went to my last post and copied everything for you. Here is the scoop on the AutoZone/NAPA parts you can get for your zook.
AutoZone
Front Red Ryder shocks - 81440
Rear Red Ryder shocks - 81538
These shocks sell for about $10 each. The rear shocks measure 14.5" compressed and 24" extended. I would imagine the fronts measure about the same. To use either of these shocks you will need to relocate your shock mounts. They give a pretty descent ride on the street and off-road and are a lot less expensive than some other name brands.
AutoZone also has U-joints for the Samurai that run about $7 and are greasable. Both Yankee Tim and I have used them with great success.
NAPA
Front extended brake hoses - 38541
Rear extended brake hoses - 38688
If they can not get lines as soon as you like, you can marry two sets together using four of the NAPA brake line nipples - 3325.
Tim Martin
87' Samurai, 1.6L, Calmini 40mm Mikunis, Pacesetter header, 2" exhaust, MSD 6AL ignition, 5.5" SPOA, 1" shackle lift, CJ-5/Samurai springs, 31" High-Tec retreads.
