1. Fill our your Profile, it helps...
2. Connect the gauge directly to the intake manifold vacuum. The engine must be at operating temperature. Start the engine, and run it at normal idle.
Normal Vacuum is 15-20 inches of mercury at idle. Cranking with the engine not starting reading should be about 1-4 in-Hg. A good engine should produce about 15-20 in-Hg at idle and about 19-21 in-Hg at 2500 rpm. Rev the engine up and down, note the gauge reading. During hard acceleration the vacuum shoud read about 0 in-Hg. During normal deceleration the reading should be around 21-27 in-Hg.
Good Jeepin'
Larry
Good Jeepin'
Larry
