Is the rear transmission mount on the 1.3L and stock tranny supposed to be a rigid mount? Or should I be able to lift the tail of the tranny out of its rubber cradle?
Also, the mount to the tranny is setting just slightly of center in the rubber "cradle" attached to the crossmember tranny mount.
I'm getting some vibrations at certain speeds with the new transmission I just installed.
Any help would be appreciated. Thanx!!
There can be some movement because of the rubber mounts but, it sounds like you have a torn mount. Trail Tough has got new mounts or check out the poly mounts offered by SpiderTrax or RRO.
-Farther
Farther:
Thanks for the post. There's some movement all right...I can completely push up the rear of the transmission and separate it from the mount attached to the cross member. And since I was getting some vibrations, I thought something was amiss.
So the two separate rubber mounts should actually be one??
