On the outside frame rail on the drivers side in the back , there is hole on the side of the frame and a hole on the bottom of the frame. What I did was drill another hole so that I now had 2 holes to hold the tow hook. I bought grade 8 bolts that were just long enought to fit through the tow hook, frame, lock washer and nut.
I put the bolt through the hook throught the frame, managed to slide the lock washer on and slide the nut on through the hole on the bottom on of the frame. I was able to slide a box wrench thorugh the hole to hold the nut and I tightened the head of the bolt.
Works great
Works great
