It is time to do some spring work on the rear end. I have a set of springs from a little Cherokee that I think will work pretty well, but, it will require the relocation of at least the rear attachment. The process would be simplified significantly if I could move the springs under the frame, instead of having to fab a mount out in space outboard to the frame. I understand the fabrication obstacles before me, and I can pull it off either way, I just need to know what negitives this option might represent in terms of handling. It seems like articulation would be better, but on road sway would be worse. What have you done.
Thanks.
Thanks.
