Is this a good recovery point (for rear). The author suggests fixing it with grade 8 bolts all the waythrought the frame rail.
In reply to:
Basically, the load ghets distributed to both rails, that's the only difference.
[/ QUOTE ]1. But that's important!
2. You don't crush or bend one frame rail by doing that...
3. If you can pull from the middle, between the frame rails, so much the better.
4. Even with thses aftermarket bumpers... I still favor sleeving the holes and using backing plates.![]()
In reply to:
2. It's covered by the rear crossmember.. which.
a. Is tack welded on to the tail frame sections.
[/ QUOTE ]
Hmmm... How's about installing rear tow points to that crossmember? Would that be any good?
In reply to:
[/ QUOTE ]
Yeah just like my mate didI then yanked him out of a mud hole and the whole crossmember came clean off including his tank skidplate and the tank strap then went on to puncture his tank... NOT a good idea!!!![]()
