Hello all....glad I found this board!!! Anyway, I'm installing a Budget Boost from TeraFlex on my 1997 TJ....the first three corners went fairly fine....however, the last corner is being a real bear....I am unable to reconnect the lower suspension arm in the rear....I disconnected it from the frame in order to get the play in the coil to remove it then put it back in with the spacer....anyway, it just wont line up....the shock and the sway bar link are both disconnected in order to give me the play in the axle that I think I need....any help would be great!!!!
Thanks,
Jim
Thanks,
Jim
