So I did a rear disc swap this fall on my model 20 rear (84 CJ7 power brakes). I bought the kit from stainless steel brakes corp. I believe the rear calipars are from a crown vic or something simalar, anyways they have combined parking brakes in them. I installed a corvette MC because I was getting no pedal with the stock one.
I havent driven it much since the swap but have not been happy with the brakes performance at all, the original setup with rear drums stopped much better. Now I drove in the snow and ice the other day and slammed on the brakes and the rear tires will not lock up at all. If I drive up a dirt hill and stop I will slide back down backwards because only the front brakes are working.
I have the original proportioning valve which I believe is the problem. How do I "gut" it like I have heard people talk about? Or do I need to get an adjustable valve and does it take place of the stock one or does it go inline somewhere else.
The last time I bled the brakes I started from the rear. I was getting a very good pedal but as soon as I started bleeding the fronts the pedal got softer and softer as I progressed. I believe this has something to do with the prop valve not working good with the 4 wheel discs.
Also the pedal feels much harder than I think It should. after a certain point it does not matter how hard you push the pedal you still stop just as fast. The brake booster is working cause it is even harder to push with the vaccum hose unplugged.
I have ruled out bleeding as a problem because I have gone thruough two bottles of fluid by now and no progress as a result. It is also much harder to stop the vehicle in low range because of all the added torque. Needless to say I will not be doing any wheeling with the brakes this way, especially after the 33" SSR's go on.
Help please??
Help please??
