I have a 1984 Bronco. I've had rear brake problems for ever maybe 10 years. I've had it to several brake shops including the Dealer they can't find anything wrong. Everything has been replaced at least once. Master cylinder, proportioning valve, brake cylinders, the shoes (currently using Ford shoes) and all the hardware, re-cut the drums, everything. The brakes don't seem to adjust up and then I think they glaze up and flat don't do a thing. Even when the pads a new and a fresh turn on the drums they don't seem to be that good. As it sits now I can set the parking brake as hard as I can, put in drive at an idle and it will roll on a flat surface. I am now considering converting to rear disk brakes can anyone suggest where to find a conversion kit if it exists. Or can anyone help with my problem. Dean
PS cables have been repaced also.
