1 - 20 of 27 Posts
I keep hearing about how bad the little Raptors are and buy this one or buy that one. Well its time to put a end to it! My son Raptor 50 does 30+ mph. Oh yes that right. The Quads was design for small riders in mind. Small handlebars, brake handles and switchs for little hands. what happens when you put him on a bigger Quad? Well you know.Now back to make the 50 and the 80 faster. They both have different things done to them at the factory. The 50 more because it was design for smaller rides. You have to start with the carb. #1 rejet carb (main jet 80. pilot jet 12.5 replace the slide with part# 2HX-14112-35-00 also need to replace main nozzle to part# 2HX-14141-78-00. Ok carb done let move on.remove the two screw on throttle housing, you will see a gold bracket you need to replace with part# 36B-2625H-00. NOW YOU HAVE FULL THROTTLE! on the 80 dont replace the slide or the bracket just rejet. remove all of the air cleaner assy and install KN air filter with outerwear. this is part one of many mods for more wait for more post or go to www.raptor80racing.com ask for al. great guy will help you with all your needs.Yamaha Rules dont let anybody tell you different. My sons 50 next to my wife Blaster. open attachment above to see picture.
How does rejetting the carb help with the speed on the raptor 50? The rev limiter is electronic, in the cdi box, and once the unit hits 2300 rpms it kicks in and the unit won't go any faster no matter what the air fuel mixture is.
well you have to start little at a time. if you do the first mod (carb) the quad will have burst of speed. yes, it will hit the rev limter quicker.but the youth will back off the throttle will playing around. if you trail ride and looking for top speed. You need mod 2 which is changing the size of the tires,mod 3 is removing rev limter with one that can be adjusted.Yes,that can be done!the new part will be out by the end of the year. its being test at this time we will have them no later then mid jan.I posted this just to let know it is coming. PS before you go out and buy bigger tires. we have new hub that will change the bolt pattern of the quad to 4/100.
Ok MOD #3. At this time all CDI boxes have fail. I at this time am using a Raptor 80 wire hardness and CDI box. This replacement is very easy. remove old wire hardness and Raptor 80, the CDI will not mount on to old bracket. You will need a piece of metal 1" by 6" long drill to holes. by doing this change it will double in speed.
Raptor racing,
Are you suggesting to use the wire hardness and CDI of Raptor 80 on the Raptor 50? Then modify the bracket to fix the new cdi?
Hey all, I have found this thread while researching why my son's Raptor 50 is so slow and gutless. Raptor50racing, I see your comments above, and I am intrigued. I know that this little 50cc beast is capable of so much more than the factory set it up for. I would like it very much if you could tell me what you paid for the raptor 80 CDI and harness. We have two problems with ours. first the engine is hobbled with this CDI. (a 4 stroke has all it's performance in the top end which this one cannot attain) secondly the clutch slips, this sux for trying to get up a hill, this one can't even get out of a ditch.
I feel that the clutch issue is caused by the engine not being allowed to get to it true HP and engage the clutch fully.
Please tell me what you paid for the CDI and harness. and if you have learned anything further on new 50cc CDI's
Thanks in advance
look in e-bay fro the parts. I paid $35.00 for cdi unit and the harness at the dealer $85.00. You need to do carb mod to get it full trottle.
it will not change the rpm by doing the carb mod. it has more power till it hit rev limter. got to do both, the carb and wiring harness.
raptor50racing, are you saying that the raptor 80 harness will plug right into the 50 with out any splicing and such?
I got a cdi and harness off of ebay still waiting on it so I just wanted to get prepared.
Discussion Starter · #11 ·
i see there is a raptor50 aftermarket cdi unit now,is this yours?
what about single and dual a-arms?
you should post on a couple of other mini-quad sites regarding 50 hop-up parts, there are many wanting them.
Discussion Starter · #12 ·
the only mod will be on the left brake assy wire. remove the ends off old one and put them on the new (80) that it
Discussion Starter · #14 ·
I installed the procomengineering CDI unit, it works excellent. ( 2 min. install ) The Yamaha parts gal couldn't locate the main jet 80 she needed to refence it from another motorcycle or quad and the replacement part for the gold bracket P.N. 36B-2625H-00 didn't show up as a valid number everything else is on it's way. Can you help with any info for these 2 parts? Thanks, Mrfiberman
Discussion Starter · #15 ·
Procomengineering.com has the cdi unit for 137.50 mine was delivered in 2 days it took 2 minutes to install and there was a noticable gain in speed.
Discussion Starter · #17 ·
raptor50racing, you stated that you put a Raptor 80 CDI on a Raptor 50. This doubled the speed on the Raptor 50. I would love to do this aswell, but the research I just did leads me to believe this is not possible. The 2 CDI's are completely different in the way the wires connect? The wires on the 50 CDI look to be internal where the 80 CDI has wires that are external? I got this info from an online parts diagram for both atv's.
Is there any way you could post a photo of how you wired up the 80 CDI onto the Raptor 50? I also understand that a new custom mounting bracket is needed, that is no problem for me.
There are currently no stock Raptor 80 CDI's listed on eBay..javascript:void(0)
/ubbthreads/images/graemlins/frown.gif /ubbthreads/images/graemlins/frown.gif I'll keep checking though!
Thanks in advance!
Discussion Starter · #18 ·
raptor50racing
sent you a request for some further information on the 100cc engine replacement.
atvingnc
Discussion Starter · #19 ·
raptor50racing
Did the Raptor 50 engine swap require changing the CDI, regulator or any of the wiring harness ???.
atvingnc
Discussion Starter · #20 ·
The 50 can rock
I just wanted to write and validate that with certain mods the Raptor 50 isn't the gutless snail everyone accuses it to be. I have just begun, with the K&N replacement not the clamp on, Big Gun CDI and it is noticability faster. I still need to jet the carb, Change the slide and an exhaust then it will keep up with my other son's CRF 50. If anyone has info on gearing up grades for more top end Please reply. http://forums.off-road.com/attachment.php?attachmentid=75030&stc=1&d=1228759848
1 - 20 of 27 Posts
