Does anyone have any information, costs, web sites or opinions about converting a factory air conditioning system on a Wrangler or Cherokee (1988 vintage) from the old R12 refrigerant to the new R134a refrigerant? Thanks in advance for any help.
Tom
I had my ac converted about 4 months ago, it worked for while till it start to leak!! This conversion is somewhat simple, they have to "retrofit" the hi side (I think) to accept R134a. If your o-rings are in good condition and you might not get leak(s), but ask them to put some leak detector alone with R134a (it is going to be easier to detect any leak(s) in the future.
It should cost around $150 and all they did was evac your old R12 and putting some oil and new R134a. Keep you eyes on your sight glass and look for any bubbles after the conversion, bubbles usually indicated leak in the system (fact, late model ac units are closed units).
Good luck,
[email protected]
Be careful! I had an 88 Grand Wagoneer that needed a new a/c compressor. I went ahead and did the conversion; the freon is about $5/can compared to about $20/can, you need the retro kit (o-rings, valves, etc.) about $20. After I got it installed, I developed a leak like you did. The R-134 runs at a higher pressure and is also thicker (I think?) If you think your hoses are bad, replace them. The guy that put my compressor in put too much freon in, that's probably what caused the leak, I got some hoses made put the freon in, according to what we thought the specs were, and 15 minutes later, the hose blew; luckily our faces weren't in it but I got about a $50 rust proofer for my hood. I got the hoses made again and made the parts store give me the exact specs for the amount of freon to add. For mine it took 4 cans of R12, in R134 it should take 2.5 cans. Moral of the story, go by the book specs, not somebodies formula. Also, if it doesn't cool right away, or what you are used to, spray some water on the condenser, it should cool. If you don't like the way it cools at stop lights or at idle, buy an electric fan to keep the air flowing through the condensor.
