Guest
·Hi all, I know that this stuff has been covered before, but I really need some help quick and I couldn't find the old posts about it.
I went to the junkyard today to look for some upgrade axles for my '94 YJ, and here's what I found:
Front: Dana 44 from an 81 Wagoneer Quadratrac (I think). It has a driver side differential, on which the center of the yoke is 5.5 inches inboard of the inside of the driver side leaf spring. I haven't measured this dimension on my Dana 30 yet, so I'm not sure what it is. The axle is about 61" wide between the wheel mounting surfaces on the rotors, and the spring perches are about 31.75 inches apart. The drag link is approx 26" long, But I haven't measured the YJ's yet. According to my measurements so far, everything seems to be darn close to the YJ's diensions. This axle has no hubs, could I put regular lockouts on it?
Rear: dana 44 from a 78 Wagoneer Quadratrac. The measurements between the spring perches and the overall width are almost exactly that of the front axle above.
Questions: What would be involved in this swap? See below:
-Steering considerations - would I have to grind the knuckles and rotate to get a good caster angle, or would they work OK as-is? What about the drag link? Any ideas?
-Do my measurements seem right? This appears to be too good to be true.
-I forgot to check the axle ratios. Any idea what the stock ratios are, or at least what they could be?
- Pinion yoke - will I have to change them, or will the ones that are on there work? If I have to change them, what would I need?
-What else would I need to accomplish this swap? If anyone has part numbers of stuff that I would need, that would be great.
I hope I've covered everytihg here. If anyone has suggestions on anything else, I would appreciate it. I realize that I would have to get new wheels, but that's OK...
Thanks a lot for your input...
Both have 6x5.5 lug patterns
Marc
Contagious Off-Road
Marc
Contagious Off-Road
