Guest
·I just got back from the pick and pull with a cap, base, wires, rotor. I also got the coil and bracket all this for only $11.24. I could not find and f150 so I got my parts out of an 83 econoline (cap, rotor, plug wires), 94 econoline 150 (coil and bracket). I got the cap base out of a 79 fairmont. I found that if you look around at the various Ford product you find you can get them off of trucks, vans, and cars it makes it easier to find the parts.
My question is where do you use the springs for the distributor? I am talking about the Mr Gasket kit that you say to get for the upgrade. When I look at a diagram for the distributor I don't quite understand where the springs are used at
Thanks for your help als
