1 - 1 of 1 Posts
Vendor
Whether you need a new set of flares to replace an old factory set or want a new set to compliment your Jeep's lift or aftermarket tires, Lund Fender Flares has everything to cover your needs and even more! Now you can use the advantage of the Lund Promo and save $50. Receive a $50.00 Prepaid Visa Card when purchasing a 4-Piece set of Lund Fender Flares. Don't miss your chance! This promotion runs from January 1 through March 31, 2017.
All Lund Fender Flares are designed to provide extra protection from rocks and debris for your Jeep's body and paint job. These are made from Tri-Flex ABS thermoplastic material to maximize the durability. They feature a hard scratch-resistant surface, able to withstand the most extreme abuse. The fender flares install in minutes and do not require any cutting and use pre-existing factory holes to fasten securely.
Lund™ | Truck Accessories, Tonneau Covers, Running Boards - CARiD.com
Make sure your Jeep does not get pelted with rocks, ice, salt and mud by investing in a set of Lund Fender Flares - you won't regret it!
1 - 1 of 1 Posts
