1 - 17 of 17 Posts
Well last night Mikej678 stopped by the shop, And while i worked on finishing up KoKo's tire carrirer/rack. He disasembled the Toy case for new gears. Once that was done I milled the case to except them and it is now ready for reinstall (except for the one broken bolt in the case at the mount, that is realy stuck) Anyway The night before I rebuilt the first case and added the doubler, so today we should have after some more machine work a full motor to end case ready to install in to the Rat.. Pics to follow later
In reply to:
I wish I understood any of this...doublers, 2 t-cases, ringers, adapters....seems like it just wouldn't all fit under there
[/ QUOTE ]
Ah yes grasshopper it will all fit quite nicely with a 109" wheel base
And in case you realy dont understand
RingR adapts 1.6 to Toy trans
AA Doubler mates 2 toy case together
2:28 front case 5:1 gears in rear case Trans 1st gear 3.9 R/P 5:71
In reply to:
[/ QUOTE ]
How the hell do you expect to go 100 MPH with THAT ?
Heck, marlins is only 24 HPM
How do you expect to get 100 HPM with that setup?
Discussion Starter · #16 ·
Well, after picking up 2 clutch disk's and a new pressure plate. I machined the first disk without problems. We proceded to yank the 1.3 and trans, bolted the 1.6 to the RingR, toy trans,case doubler, case and dropped it in the frame rails, where it is currently sitting. I have to pic up 2 new stock motor mounts. then work on the trans x-member.. I will popp a few pics later. but all in all a good day..
good progress for a weekend, need pics though! I just wrapped up my doubler and automatic trans install. Its geared kinda low for the street but the low-low off road is gonna be nice, cant wait to try it out in the rocks. I took it for a ride around the block and I think I am gonna like the automatic
1 - 17 of 17 Posts
