Here are the answers to some of the posted questions about pre-lubriction:
YES, you CAN crank a Chev-Lay longer to get the oil pressure up, IF the starter is adjusted perfectly.
As you probably know, them Shiv-Lays do not have a very precise starter mounting system
and must be shimmed to get the correct clearance.
TR told us how to do that and that info flew into my brain and stuck there. You slide a 1/8" drill rod between the starter shaft and the ring gear.
My SB350 cranks with the smoothness of Butter,
and the starters last a ****'s age,
so I don't worry about "free cranking" it to get the oil pressure to show.
ALso, I use that big two-quart filter
so it does take a little bit longer sometimes to get pressure up if it has been sitting.
THE CATS we ran all had the compression release wherein you could lever the intake valves full open while you rolled the engine over, thereby relieving the pressure on the crankshaft that 20:1 compression on a 4-14" bore diesel engine would normally cause
. That was a great system and saved us a lot of needless crankshaft bearing wear.
BUT.....HERE is the definitive example of ALL TIME, and is what convinced me that pre-oiling was so darn essential.....
I was in a big creamery doing an Infrared Inspection in their "engine room"....actually a room full of HUGE ammonia compressors.....and the head engineer gave me a little demo. He set up a DIAL INDICATOR on the huge compressor shaft with the stem of the indicator vertical. He zeroed the dial and then he went over and pushed the "Start" button on the big compressor motor. The start sequence began with the electric lube oil pump starting up first. within just a few seconds, that HUGE SHAFT raised up just a few thousanths....like maybe three (.003) or four (.004) of an inch. THEN the compressor started and the shaft NEVER DID go back down....it was literally riding on a film of oil, not even touching the big pillow block bearings.
He told me how many hours the machine had on it and it was a mind-boggling amount; almost incomprehensible since the machine dated back to WWII.
The squish tank engine pre-luber would be my choice for since it also helps to smooth the spikes and dips in oil pressure. You could make one if you just got the accumulator from a farm sprayer or a hydraulic system and used a lever valve that you could operate from inside the cab to "trap" oil under pressure in the tank before engine shutdown, and release it as you got ready to restart. It isn't rocket science by any means.
