It's safe.
If it hasn't failed from 84 to present, the flaw isn't going to show it's self, and besides, Ford had at least 21 versions of this coil from 82 to present, and only one of those was flawed (used on 302 V-8's). All are condensed in one part number now...
It wasn't overheating modules anyway...
In worst case situations, it supplied high voltage to the module coil switching circuit, and killed the switching drivers, and the module just failed to fire the coil anymore.
--Most of the time the coil just stopped working when the primary circuit opened.
Accounts really quickly for a bunch of the failures in the DuraSpark modules on the E.E.C. equipped vehicles, (attached to the distributor).
We use the First generation of the DuraSpark module (attached to the finder well), so the problem is moot here...
The problem never existed in aftermarket coils, and has been corrected in Ford coils from late 95 on.
The two overheating failures posted here, one was old, and the other was old and LEAKING!!! If that isn't enough warning to replace the module, I don't know what is!
I don't think we can blame the upgrade on the two module failures...
They may just have enough ignition now to find the flaws in their old modules...
REMEMBER, Ford has upgraded the type 1, DuraSpark Blue Grommet Module 4 times in the last few years of it's use, do the older, (75 to 83) modules still have flaws that haven't been corrected.
If you buy one, buy the premium module if you can afford it. That will insure you get all of the upgrades.
It's only $16 to $35 for cheap to premium modules, and if your old one hasn't failed yet, it can always be used for a 'limp home' unit...
Does this help clear up anything...?
Aaron.
