1 - 1 of 1 Posts
Re: power window switch problem.............NEED H
sounds like the window motor armature has a parcial open or high resistance. It works ok w/ no load, but as soon as you make work hard,amp draw goes higher then the armture can handle. Placeing a hammer head next to the feild increases the magnetic field giving a small boost. Smacking it w/ a hammer may cause the open to close for a sort time. Either way the motor is bad.
Wes
1 - 1 of 1 Posts
