My wife's 1998 Tahoe has power locks. The fuse in the #13 slot that is responsible for the locks, cigarette lighter, and power outlets keeps blowing. It will work for a day or a half of a day - but blows. It calls for a 20 amp fuse in the area. When it does blow, the remote button will open the doors, but not the back hatch - and the button on the dash will not open the back hatch when the fuse goes. Any suggestions? Where to start looking?
Thank you
Sounds like you have a wiring problem. You might want to have an electrical specialist look at it. Have you tried replacing the relay? I'm pretty sure it's under the dash there by the fuses. It could also be the power window switch too. But sounds most like it's a short in the wiring.
Most of the time that I see this complaint, it's due to something being stuck in one of the power outlets (cigar lighter) or the cell phone charger is faulty causing the fuses to blow
exactly as above, i dont know how many pennies and dimes i have had to dig out over the years in the cigarette lighter outlet
