well under the frame i have some flat stock.. 3" wide welded up.. then those front blocks (spring mounts) are welded on it.. the angle iron is welded across the top.. side.. inside.. outside.. bottom... where ever i could.. its also tied into the winch mount
the rear has steel plates tied into it.. on the back side of the frame..
2x4" rectangular tube 3/16" wall. 1" thick tow tabs made from 1/2" plate sandwiched together on the front and then 1/2" plate running through the bumper into the frame rails.
